Millelr CST 250 What comes next?
by Danny
I have a Miller cst 250.It is DC current with Lift Arc.I want to Tig with it,but im not sure what i will need to get going.Ive got a air cooled torch,regulator,argon bottle,and hose.Is there anything else i need,and what are the steps for hooking them all up?
in case you dont have one , here is a link to the manual
pdf manual
http://www.millerwelds.com/om/o2237h_mil.pdf
on page 14 there is a diagram of how to set it up
it looks like you need the style torch with a separate argon hose to go straight to the flowmeter and also a valve on the torch so you wont waste argon.
the torch valve is not a must to get started welding if your argon is close by and you can remember to turn it on and off...but you are going to want a torch with a valve.
regards,
