"Mild Steel to Chromoly"
by Anthony
(N.Las Vegas)
Can you weld 4130 chromoly to Mild Steel ? If so will the strength be the same, or will it be different because of dissimilarity in the metal ?
I personally never tried welding these two metals together. What type of filler would I use ?
On Chromoly I normally use Oxyweld 65 brand filler. Of course the process I use is Tig (DCEN).
I am asking this question because I am building a race car out of chromoly, but the brackets for the 4 link are mild steel (they were cheaper) or should I spend the extra money for chromoly?
I really enjoy your site and hope to have more questions that baffle my mind LOL.
jody here from weldingtipsandtricks.com.
I would use E70S-2 mild steel tig welding rods.
and btw, I would use this for all your chromoly welds. the oxweld does not have any good stuff like silicon to scavenge the junk.
i bet it spits sometimes.
with E70S-2, the welds will be a tiny bit stronger than the mild steel but not quite as strong as the chromoly. This is normal.
If its thicker than .125" a preheat is called for to slow the cool rate.
good luck,
