Mig welding settings. There's voltage and there's wire speed. Thats all folks!
mig welding question on voltage and wire feed settings.
Question about mig welding settings.
hi I have a miller 115 volt welder and there are voltage settings on the welder, what does that indicate and what settings should it be on? thanks
Answer to mig welding settings question
Here is my down and dirty explanation. If you are using .023-.025" bare wire with argon/co2 gas mix, your wire feed range is 100-400 inches per minute. 100 being for the thinnest steel you can weld, 400 ipm would be used for the absolute thickest steel the machine would handle. Voltage is another story. I say set the wire feed speed first. then get a piece of scrap metal the same thickness you want to weld and adjust the voltage until you get a nice bacon frying sound. Too little voltage and it will snub and sound like a drive by. Too much voltage and the wire will try to burn back into a ball or the sound will be a rattle or hiss. You will see....its very hard to describe but just try it. so if you wanted to weld 20 ga. or about .030" thick. you would set the wire feed speed to 100. if it does not read in inches, just pull the trigger and count to 6 seconds, measure in inches and add a Zero. 10 inches would equal 100 inches per minute. hey jody thanks for replying back to my email. it makes sense now that i read what u had sent. my final question is what about the argon gas, my gauge is broken and i wanted to know how much gas to open from the valve full or not full, also how much do those gauges cost its a dual gauge? Thanks for your help I hope you mean argon mix. Straight argon will only work on really thin stuff. you need 75/25 argon/co2 or straight co2. mig welding settings not clear enough?
