MIG WELDING 2F TEE FILLET 11GA CARBON STEEL LINCOLN 210MP
20volts 280 IPM .030” er70s6
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = TEE
POSITION = 2F HORIZONTAL
VOLTS = 20 volts
WIRE SPEED = 280 IPM
WIRE SIZE = .030"
GAS FLOW = 20-25 CFH C25 GAS
CTWD = 3/8”-1/2"
FILLER METAL = ER70S6
TIPS: BOTH PUSH ANGLES AND PULL ANGLES CAN WORK WELL PROVIDED THE ANGLE IS KEPT MINIMAL
A relatively short stickout aka contact to work distance CTWD of 3/8” to 1/2" makes a big difference. The technique shown is to keep the arc toward the leading edge of the puddle
