MIG Welding 11ga Square Tubing with .030" er70s6
scroll down for settings
THICKNESS = 11GA
WELD TYPE = Fillet welds and groove welds
JOINT TYPE = square tube
POSITION = FLAT AND HORIZONTAL
VOLTS = 18.0 volts
WIRE SPEED = 230 IPM
WIRE SIZE = .030"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
FILLER METAL = ER70S6
TIPS:   A relatively short stickout aka contact to work distance CTWD of 3/8” to 1/2" makes a big difference.The technique shown can be a series of cursive e’s to  keep the arc toward the leading edge of the puddle
Did you know?..
