MIG CARBON STEEL DOWNHILL OPEN ROOT 1/4" PLATE 30 DEG BEVELS 1/8" GAP 18 VOLTS 230IPM WIRE .030"
THICKNESS = 1/4"
WELD TYPE = groove
JOINT TYPE =open butt
POSITION = 3G PLATE downhill root
VOLTS = 18 volts
WIRE SPEED = 230 IPM
WIRE SIZE = .030"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
TUNGSTEN  =
FILLER METAL = ER70S6 .030"
The technique shown is a very slight side to side motion while keeping the arc on the front edge of the puddle while not far enough to shoot wire thru the gap.
Did you know?..
