THICKNESS = 1/4""
WELD TYPE = groove
JOINT TYPE =open butt
POSITION = 3G PLATE downhill root
VOLTS = 18 volts
WIRE SPEED = 230 IPM
WIRE SIZE = .030"
GAS FLOW = 20-25 CFH C25 GAS
CTWD = 3/8”-1/2"
FILLER METAL = ER70S6 .035"
The technique shown is a very slight side to side motion while keeping the arc on the front edge of the puddle while not far enough in front to shoot wire thru the gap.
