MIG CARBON STEEL 1/4” THICK UPHILL 5F TUBE PLATE
scroll down for settings
Once and for all pushing vs pulling mig welding
Video of Dual Shield Flux Core vs 7018 Stick Electrode vertical uphill using an Esab Rebel 285
TIG Welder Settings for Steels and Aluminum with Quick Videos Showing settings and results
Did you know?..
There are over 800 videos over at welderskills.com from beginner stick welding to advanced TIG... to down and dirty repair videos on farm equipment...to 6G Pipe certification test videos.
THICKNESS = 1/4” .250, 6mm
WELD TYPE = Fillet weld
JOINT TYPE = tee joint
POSITION = 5f vertical uphill
VOLTS = 17.7 volts
WIRE SPEED = 289 IPM
WIRE SIZE = .035"
GAS FLOW = 20-25 CFH C25 GAS
CTWD = 3/8”-1/2"
FILLER METAL = ER70S6
The technique shown is simple series of V shapes that traces the front leading edge of the puddle
var l = window.location.href,
d = document;
