MIG WELDING CARBON STEEL PIPE 3/8" THICK 5G FILL AND CAP UPHILL
scroll down for settings
Did you know?..
There are several hundred videos over at welderskills.com from beginner to advanced... to down and dirty repair videos on farm equipment...to 6G Pipe  certification test videos.
Whether you are a student working on passing a welding test, hobbyist, or a working welder who wants to sharpen up, I want to encourage you to take the free 7 day test drive and get access to all the courses and over 700 videos.
THICKNESS = 3/8"
WELD TYPE = groove
JOINT TYPE =open butt
POSITION = 5G pipe weld uphill fill and cap
VOLTS = 19 volts
WIRE SPEED = 210 IPM
WIRE SIZE = .035"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
FILLER METAL = ER70S6
The technique shown is a weave that sort of resembles a rainbow arc  that keeps the arc on the leading edge of the puddle
5g mig pipe
