27 VOLTS 400 IPM WIRE SPEED WITH 3/64” 4043 WIRE
WELD PROCESS = GMAW, GAS METAL ARC WELDING
METAL TYPE = ALUMINUM ALLOY
THICKNESS = 1" INCH TO 2"
WELD TYPE = Fillet
JOINT TYPE = TEE
POSITION = 2F
VOLTS = 27.0 volts
WIRE SPEED = 400 IPM
WIRE SIZE = 3/64” 4043
GAS FLOW = 25-35 CFH 100% ARGON GAS
CTWD = 1/2” - 3/4"
FILLER METAL = ER4043 3/64"
ADDITIONAL SETTINGS = PREHEAT OF 200F
TIPS:A longer contact to work distance CTWD of 1/2”-3/4” helps with spray transfer aluminum mig welding.
