Mig Welding Aluminum 1 inch thick Settings 2f fillet welderskills
Scroll down for exact settings shown in video
I know that 3/64" diameter wire would have been a better choice but .035" 4043 was all I had on hand.
Hybrid TIG and MIG gloves at weldmonger.com
click on gloves to learn more
scroll down for settings
aluminum mig
Did you know?..
WELD PROCESS = GMAW, GAS METAL ARC WELDING
METAL TYPE = ALUMINUM ALLOY
THICKNESS = 1 INCH TO 1/2"
WELD TYPE = Fillet welds
JOINT TYPE = TEE
POSITION = 2F HORIZONTAL
VOLTS = 25.0 volts
WIRE SPEED = 590  IPM
WIRE SIZE = .035” 4043
GAS FLOW = 25-35 CFH 100% ARGON GAS
CTWD  = 1/2” - 3/4"
FILLER METAL = ER4043 .035"
TIPS:A longer contact to work distance CTWD of 1/2”-3/4” helps with spray transfer aluminum mig welding.
