Mig Welding 1/2" thick Aluminum gusset settings video
looking for an affordable high quality auto dark welding helmet?
click on pic below to learn more
ARCONE 1000F-0100
mig aluminum
scroll down for settings
Did you know?..
WELD PROCESS = GMAW, GAS METAL ARC WELDING
METAL TYPE = ALUMINUM ALLOY
THICKNESS = 1/4" INCH TO 1/2"
WELD TYPE = groove
JOINT TYPE = flare bevel
POSITION = 2F HORIZONTAL
VOLTS = 25.0 volts
WIRE SPEED = 590  IPM
WIRE SIZE = .035” 4043
GAS FLOW = 25-35 CFH 100% ARGON GAS
CTWD  = 1/2” - 3/4"
FILLER METAL = ER4043 .035"
TIPS:A longer contact to work distance CTWD of 1/2”-3/4” helps with spray transfer aluminum mig welding.
