by Adrian
(Ontario)
I am building an ultralight aircraft called a trike.
I wish to use my MIG welder to weld the 4130 N tubing which is .049" wall for the trike frame.
I am reasonably good with my MIG welder and intend on pre-heating the material before welding.
I would like to weld the frame myself and prefer to avoid the purchase of a TIG welder which I have never used.
I could also use my Oxy-Acetilene torch to weld the frame but I have waaaay more experience with the MIG.
Can I use my MIG to get good welds on 4130 chrome moly?
Thanks
Adrian,
I have to say that even though I would not recommend mig welding for a 4130 ultralight, I do think it is possible with a good preheat.
but it will depend on establishing good procedures and following them.
if you have a temp crayon, it will help you to get the same preheat each weld.
and if you decide to do it, i would recommend welding a bunch of test welds using scrap pieces of the same size and thickness and beating them in a vise with a big hammer to check ductility.
thanks
Comments for Mig welding 4130 tubing
