Mig Welding Carbon Steel 3/8" 3g plate test open root uphill settings
scroll down for settings
Did you know?..
METAL TYPE = CARBON STEEL, COLD ROLLED STEEL, A36
THICKNESS = 3/8” with 30 degree bevel
WELD TYPE = uphill  root pass for open butt Groove weld
JOINT TYPE =Butt Joint root pass
POSITION = 3g vertical uphill root with 3/32” - 1/8” gap and slight land around 1/16"
VOLTS = 17 volts
WIRE SPEED =161 IPM
WIRE SIZE = .035"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
FILLER METAL = ER70S6
The technique shown keeps arc on the leading edge of the puddle.
stay on front of puddle and use just enough side to side motion to control the puddle and avoid shooting wire thru the gap.
mig welding open root uphill
