MIG WELDING 3/8" 3G PLATE COVER PASS
full length video on mig welding 3/8" 3g plate here
scroll down for details and settings
scroll down for settings
Did you know?..
THICKNESS = 3/8” with 30 degree bevel
WELD TYPE = cover pass for open butt Groove weld
JOINT TYPE =Butt
POSITION = 3g vertical uphill
VOLTS = 17.7 volts
WIRE SPEED = 200 IPM
WIRE SIZE = .035"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
FILLER METAL = ER70S6
The technique shown is simple z weave that keeps arc on the leading edge of the puddle
