Mig Welding 11ga steel corner joint in 2F position
Flat is almost the same as 2F but If you want to see the flat 1F position, click the youtube video below
115-volt-mig-1f-flat-corner-thumb
Mig welding 11ga corner joint settings and techniques and all the tips you need to be successful.
It doesn't matter what the part is, if it is made from 11ga steel and its a corner joint in the flat position, then this page and video are for you.
Did you know?..
If you are struggling in learning how to weld with mig, stick, tig, or flux core, we have a free 7 day trial period set up for you at welderskills.com where you can access courses on every type of welding along with over 700 other welding videos to help you learn how to weld better.
welderskills.com is a private member video site where we strive to make concise videos on welding without any BS, loud music, long intros and all the other stuff you have to tolerate on youtube.
Take the free trial and learn along side some of the best welders I know.
