MIG WELD CARBON STEEL THIN WALL SQAURE TUBE .063" FILLET
Once and for all pushing vs pulling mig welding
Video of Dual Shield Flux Core vs 7018 Stick Electrode vertical uphill using an Esab Rebel 285
TIG Welder Settings for Steels and Aluminum with Quick Videos Showing settings and results
PROCESS - MIG GMAW-S, SHORT CIRCUIT MIG
METAL TYPE = CARBON STEEL SQUARE TUBE
THICKNESS = .063"
WELD TYPE = FILLET
JOINT TYPE =TEE
POSITION = 2F HORIZONTAL
VOLTS = 18 volts
WIRE SPEED = 305 IPM
WIRE SIZE = .025"
AMPS =
GAS FLOW = 20-25 CFH C25 GAS
CTWD = 3/8”-1/2"
TUNGSTEN =
FILLER METAL = ER70S6 .025"
TIPS:
A relatively short stickout aka contact to work distance CTWD of 3/8” to 1/2" makes a big difference.
The technique shown is a very slight side to side motion while keeping the arc on the front edge of the puddle while not far enough to shoot wire thru the gap.
var l = window.location.href,
d = document;
