MIG WELD CARBON STEEL 1/4" THICK 2F FILLET SHORT ARC MIG MULTIMATIC CHART SETTINGS
scroll down for settings
Did you know?..
THICKNESS = 1/4” .250, 6mm
WELD TYPE = Fillet weld
JOINT TYPE =TEE
POSITION = 2F, horizontal
VOLTS = 20.9 volts
WIRE SPEED = 456 IPM
WIRE SIZE = .030"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
FILLER METAL = ER70S6
Both push and pull angles are shown and both can work fine provided the arc is kept at the leading edge of the puddle and gun angle is not extreme.
welderskills mig settings
