MIG WELD CARBON STEEL 11GA 3F TEE UPHILL .030" WIRE
scroll down for settings
Did you know?..
THICKNESS = 11ga
WELD TYPE = Fillet weld
JOINT TYPE = tee joint
POSITION = 3f vertical uphill
VOLTS = 16 volts
WIRE SPEED = 227 IPM
WIRE SIZE = .030"
GAS FLOW = 20-25 CFH C25 GAS
CTWD = 3/8”-1/2"
 FILLER METAL = ER70S6
TIPS: A relatively short stickout aka contact to work distance CTWD of 3/8” to 1/2" makes a big difference.
The technique shown is simple weave
