MIG Settings for 3F and 4F Tees
2 of the welds beginners often struggle with are vertical uphill and overhead mig welding.
So I made this page with 2 quick videos showing the exact settings and techniques that work for both overhead and vertical uphill short circuit mig welding.
Settings for vertical uphill short circuit mig welding 3f tee 1/4" thickness
19.5 VOLTS 280 IPM .035”
THICKNESS = 1/4"
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 3f vertical uphill
VOLTS = 19.5 volts
WIRE SPEED = 280 IPM
WIRE SIZE = .035"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
FILLER METAL = ER70S6 .035"
TIPS:A relatively short stickout aka contact to work distance CTWD of 3/8” to 1/2" makes a big difference.The technique shown is simple series of upside down V motionsThis technique traces the front leading edge of the puddle and helps ensure penetration.
Settings for overhead short circuit mig welding 4f tee 1/4" thickness
THICKNESS = 1/4” .250” 6mm
WELD TYPE = Fillet
JOINT TYPE =Tee
POSITION = 4F overhead
VOLTS = 20 volts
WIRE SPEED = 333 IPM
WIRE SIZE = .035"
CTWD  = 3/8”-1/2"
The technique shown is simple serves of V’s that keeps arc on the leading edge of the puddle
