MIG Mini Course Topic #3
Vertical Uphill MIG
the link to the next video in this mig series is at the bottom of page
Quick Tips for Vertical Uphill mig welding
  • clean metal welds better so unless you are welding cold rolled steel, use a grinder to remove mill scale.
  • make sure to have the ground clamp attached directly to the piece being welded on an area that has been ground to clean bright metal. (A bad ground connection makes for rough arc starts.)
  • limit the stickout also called contact tip to work distance (ctwd) to 1/2"
  • If you are using a mig settings chart, select a thickness that is one or two steps lower than what you are welding and lower wire speed by 10%
  • Use a technique that keeps the arc on the leading edge of the puddle
  • Make the bead just wide enough to prevent the bead from crowning up
What is welderskills.com?
Welderskills.com is a Premium welding video membership site that my 2 sons built.
After posting over 600 videos on YouTube, I wanted to include other instructors who are at the top of their craft and put the videos on a private site for welders who want to go deeper and who are willing to have some skin in the game.
So I recruited some of the best welders and fabricators I know who are at the top of their craft.
When you take your free trial at welderskills.com you will have complete access to over 500 welding videos.
No long introductions, no Ads, and no nonsense.
Just real world welding videos, Zoom videos with topics such as running a welding business, AND…you will also have complete access to all of our courses which start at  $99 each for non members.
There are other online welding courses asking as much as $497 up front.
Why spend $497 up front when you can get what you need at welderskills.com at $12.99 per month and you can easily cancel whenever you feel you got what you needed?
I am not asking you to decide yes or no today..I am just asking you to make a fully informed decision, that is all.
The only way you can make a fully informed decision is on the inside of welderskills.com, not the outside.
You can’t really make an informed decision right now for the same reason you don’t buy a house without first looking at the inside.
Thats why we have a Free trial along with a Discount code for 50% off your first month
After you get on the inside of welderskills.com, you will have access to all courses and videos.
Thats when you decide to stay.…or not.
We are confident you will see the tremendous value and stay
MIGBOOK1 is the discount code for 50% off your first month.
If it’s not for you , no hard feelings.
We have made cancelling very easy with no hoops to jump thru.
Take your free trial now at weldersklls.com and don't forget to use MIGBOOK1 for 50% off your first month.
JD Brewer(@apexish)
Brad Goodman (@deepsouthdimestacker)
Roy Crumrine (@crummywelding)
Johannes (@tig_happens)
Mike Best (@BestfabLLC)
Matt Hayden (@matthaydenwelder)
Sam Hagan (@lostskills)
and others are working hard to bring you the best real world welding videos possible.
See you in there,
Jody Collier
