MIG WELDING CARBON STEEL 3F VERTICAL UPHILL TEE JOINT .035" ER70S6
scroll down for settings
Short Circuit Mig uphill requires some manipulation to prevent the bead from being excessively convex or mounded up.
The 3 main things to focus on are:
  1. Voltage and Wire speed settings that are balanced and hot enough to hit the root ( in this case 18.5 volts and 280ipm)
  2. Maintain a short stickout (contact tip to work distance)
  3. use a technique that plays the arc on the leading edge of the puddle
Did you know?..
19.5 VOLTS 280 IPM .035”
THICKNESS = 1/4"
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 3f vertical uphill
VOLTS = 19.5 volts
WIRE SPEED = 280 IPM
WIRE SIZE = .035"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
FILLER METAL = ER70S6 .035"
TIPS:A relatively short stickout aka contact to work distance CTWD of 3/8” to 1/2" makes a big difference.The technique shown is simple series of upside down V motionsThis technique traces the front leading edge of the puddle and helps ensure penetration.
mig welding uphill technique welderskills
