MIG CARBON STEEL VERTICAL UPHILL 3F TEE .035" WIRE
looking for an affordable high quality auto dark welding helmet?
click on pic below to learn more
ARCONE 1000F-0100
19 volts 250 IPM.035”er70s6
THICKNESS = 1/4"
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 3f vertical uphill
VOLTS = 19 volts
WIRE SPEED = 250 IPM
WIRE SIZE = .035"
GAS FLOW = 20-25 CFH C25 GAS
CTWD  = 3/8”-1/2"
FILLER METAL = ER70S6 .035"
The technique shown is simple series of TRIANGLES.This technique traces the front leading edge of the puddle and helps ensure penetration.
