Mig Aluminum spool Gun Settings
for 11g 2f tee
scroll down for settings used
Did you know?..
20 volts 375 ipm .035" 4043 wire 25-35 cfh argon
WELD PROCESS = GMAW, GAS METAL ARC WELDING
METAL TYPE = ALUMINUM ALLOY
THICKNESS = 1/8"
WELD TYPE = FILLET
JOINT TYPE = TEE
POSITION = 2F HORIZONTAL
VOLTS = 20.0 volts
WIRE SPEED = 375 IPM
WIRE SIZE = .035” 4043
GAS FLOW = 25-35 CFH 100% ARGON GAS
CTWD = 3/4"
FILLER METAL = ER4043 .035"
TIPS: A longer contact to work distance CTWD of 1/2”-3/4” helps with spray transfer aluminum mig welding.
