Mig 4f Tee joint on 1/4" thick steel using .035" er70s6 Quick settings welderskills
Scroll down for exact settings used
With overhead short circuit mig welding, there is a tendency for folks to use cold settings for fear that the weld will sag.
I have found that by using a short stick out also know as "contact tip to work distance" (ctwd), simply lowering the wire speed by about 10% works fine for overhead welds.
THICKNESS = 1/4” .250” 6mm
WELD TYPE = Fillet
JOINT TYPE =Tee
POSITION = 4F overhead
VOLTS = 20 volts
WIRE SPEED = 300 IPM
WIRE SIZE = .035"
GAS FLOW = 25 CFH C25 GAS or higher depending on nozzle diameter
CTWD = 3/8”-1/2"
FILLER METAL = ER70S6
The technique shown is simple serves of cursive e’s that keeps arc on the leading edge of the puddle
Overhead short circuit mig seems to go better when a short stick out aka contact tip to work distance is maintained along with settings that are almost as hot as a 2f fillet
