machine setup for uphill 1/16 FCAW
the weld is 36" uphill the size is 1/4" fillet
machines are different and even different wire manufacturers need slightly different settings.
a good starting point is this...
the settings here are based on flat and horizontal so you may need to pick a thickness less than what you are welding.
i have found the wire speed is always about 10% more than what is best for me.
