is rooting plate posible with fluxcore
by sutherland
(grampian)
i have to do a test on 50mm plate with a 3to5 mm gap root and fill with fluxcore. is this possible as i have never done a fluxcore root before.
it is possible , though not very common practice.
i have not done it so I cant be very helpful here.
anyone else out there want to contribute?
Comments for is rooting plate posible with fluxcore
Jul 26, 2014
testing NEW
by: T
It depends on t4he position you have to weld you test. Is it flat? Or a 2Grove test? It can be easily done, I learned with 3/32 flux innershield.If it's up on it's side(horizontal groove)just point your stinger straight in and keep it pointed straight in, and if you watch your puddle close you can make all 3 plates in you test coupon weld together. Then start at the bottom and build it up.
Dec 06, 2013
1/4 inch pipe 1/4 inch root NEW
by: Anonymous
I welded 1/4 inch thk 304 stainless pipe with 308 Flux core. 045 dia wire. Root opening was 1/4 inch. Ceramic backing. 26.5v 380ipm. Pushing the puddle slightly. After it was rooted I peeked inside and the root was clean. After it was rooted I turned the machine up to 28.5v and down to 300ipm. Put one fill pass and a 2 pass cover on it.
Dec 06, 2013
by: Anonymous
Dec 06, 2013
by: Anonymous
Aug 27, 2013
Flux core rootpass NEW
by: Anonymous
Have the root gap as tight as possible and get the volts down at the lowest setting allowed on the procedure
Aug 27, 2013
by: Anonymous
Aug 27, 2013
Open root pass NEW
by: Anonymous
Got a open butt plate test all flux core need to know how to run root anybody got any thing
Jan 09, 2012
6g with flux on root n hot pass n cap NEW
by: Anonymous
alright mate how did the test go,i have the same test tomorrow.i did a practice run today, went tits up on the cap and the root was not very clever.struggling on what to put the settings on for each pass..
Jan 07, 2012
flux core root NEW
by: Anonymous
ok bud thanks for the input.
test done ,on ,holiday back on monday.
get the results then,haha
