help with fluxcore settings in 3g position using 1/16th wire
by nathan
(kinsman ohio usa)
what is the best settings to use when welding fluxcore 1/16th wire in the 3g position? I am trying to take weld tests for these companies but I have really no way of knowing what series wire or what size wire till I arrive at the job site!
thats the problem, they dont give a heads up what you are up against . i guess the thinking is they want welders to be able adapt, adjust, troubleshoot, etc.
I find this lincoln pdf helpful.
you have to really dig into it, but it has lots of settings for different wires.
http://www.lincolnelectric.com/assets/en_US/Products/Consumable_Flux-CoredWires-Gas-Shielded-UltraCore-UltraCore712A80-H/c110b.pdf
