help with flux core welding
by Brad
(Hartselle AL, USA)
Do you just push your weld uphill while flux core welding or do you have to move it like you do if you was welding with a 6010 stick rod? Never MIGed and have a test Monday..please help..thanks
torch angle should be close to 90 deg or just a slight push.
do not whip.
follow the procedure and hope for the best.
trace the front of the puddle back and forth.
