help with flux core settings
by mike t
(lamarque texas u.s.a.)
what heat should i run a hot pass and cap uphill on pipe with flux core?
Sorry, but there is not enough information here to give much advice.
the best starting point is to look up the spec of the flux core wire and use the data sheet settings for the diameter and specific brand wire you are using .
lincoln electric has some really good data sheets
http://www.mylincolnelectric.com/Catalog/consumableseries.aspx?browse=104|13275|&locale=1033
