help with flux- core settings
by terry fitzwilliam
(cudahy wi.)
flat position 1 inch plate 3/32 wire what are correct settings
it really depends on the wire you are using.
here is a reference.
linclon flux core info
click on the link and select the wire that best matches the one you are welding with.
then select the diameter
then select more product info on the right bottom of the lincoln page.
the pdf file will have lots of info and settings for all kinds of applications.
