G6 test wire MAG welding
by Cristian Gidinceanu
(Denmark)
Can you please tell me what this test means exactly?
well first of all , the g6 is actually 6g
all that means is a pipe joint placed in a 45 degree fixed position.
usually the bevel on the pipe will be between 30 and 37.5 degrees with a .125" gap.
often times the root is run downhill, and the rest is uphill.
the only way to know for sure is to contact the test supervisor and ask.
every welding test is different depending on job scope.
Comments for G6 test wire MAG welding
May 17, 2013
Mag welding tips NEW
by: Ally
Hi Joddy, I am a welder for more than ten years, I would to know more about mag welding tips and tricks. I watch your videos every week, it helps me a lot, you did a great job. God bless you and your family. Thanks
May 17, 2013
by: Ally
Aug 02, 2011
thank you
by: Cristian Gidinceanu
very good information
