Flux Cored Arc Welding
by blake
(calgary)
I will be having to perform a metal-core welding test!
What can i expect from one of these tests? Will I only be performing flat welds! Will there be a root and fill involved? Or is root and fill even common procedure? Any information, plus amperage settings would be helpful! thank you.
blake
Blake,
The test could be anything from a groove weld with root and fill in vertical and overhead.
or it could be flat...
or it could be a simple t joint that gets bent or sectioned.
metal cored
here is a link to some hobart wire and it has some settings ....I have been reading a lot and speaking to people about them but i have not had the chance to weld with metal cored wires.
Comments for Flux Cored Arc Welding
Sep 24, 2012
flux cored welding overhead NEW
by: Anonymous
YOU CAN PUT A VIDEO FOR HOW WELDING OVERHEAD IN FLUX CORED. THANKS I WAIT AND YOUR PAGE IS GREAT, THANKS OR THE HELP.
