flux core speed and amperage?
by mike
(florahome, FL)
What is the proper speed and amperage for all positions on 1/4 to 3/4 inch plate while welding with 0.45 flux core?
mike,
unfortunately, there is not one setting that will work for all those applications.
I use this miller weld calculator a lot to get a starting point...
just copy and paste the link in your browser.
the settings are pretty hot but they are intended for flat and horizontal welding.
but i have found this calculator to give me a really good starting point.
The best thing to do is to get the data sheet on the exact wire you are using.
good luck,
