DUAL SHIELD FLUX CORE CARBON STEEL 1/4" THICK OVERHEAD 4F TEE
24 volts and 333 ipm with .045" lincoln 71m outershield
Most people find dual shield flux core easier than mig welding with hard wire for overhead welding.
As long as settings are good, and stickout is about 3/4" very little, or no manipulation is needed in order to make a good overhead weld.
METAL TYPE = CARBON STEEL
THICKNESS = 1/4”
WELD TYPE = FILLET
JOINT TYPE = TEE
POSITION = 4F OVERHEAD
VOLTS = 24 volts
WIRE SPEED = 333 IPM
WIRE SIZE = .045” LINCOLN 71M
GAS FLOW = 25-30 CFH C25 GAS
CTWD (STICKOUT) = 3/4”-1 “
 FILLER METAL = LINCOLN 71M OUTERSHIELD .045"
TIPS:A longer stickout aka contact to work distance CTWD of 3/4” to 1” provides best results Using too short a stickout can result in worm tracks
Did you know?..
