DUAL SHIELD CARBON STEEL 3/8" PLATE ROOT PASS 4G OVERHEAD
WMJacket-heavy-leather
METAL TYPE = CARBON STEEL
THICKNESS = 3/8”
WELD TYPE = GROOVE WELD ROOT PASS
JOINT TYPE = butt JOINT 22.5 BEVELS, 1/4” GAP, 1/4” BACKING BAR
POSITION = 4G OVERHEAD
VOLTS = 25 volts
WIRE SPEED = 360 IPM
WIRE SIZE = .045” LINCOLN ULTRACORE 71A85
GAS FLOW = 25-30 CFH C25 GAS
CTWD (STICKOUT) = 3/4”-1 “
FILLER METAL = .045” LINCOLN ULTRACORE 71A85
TIPS:
A longer stickout aka contact to work distance CTWD of 3/4” to 1” provides best results Using too short a stickout can result in worm tracks
Did you know?..
