DUAL SHIELD FLUX CORE 3/8" PLATE TEST 4G OVERHEAD FILL PASSES
Scroll down for all settings used for this 4g overhead plate test
WMJacket-heavy-leather
dual shield flux core wires are typically designed to be used with DCEP (reverse polarity).
There are several brand names and classifications and they all require slightly different settings for best results.
METAL TYPE = CARBON STEEL
THICKNESS = 3/8”
WELD TYPE = GROOVE WELD FILL PASSES
JOINT TYPE = butt JOINT 22.5 BEVELS, 1/4” GAP, 1/4” BACKING BAR
POSITION = 4G OVERHEAD
VOLTS = 25 volts
WIRE SPEED = 360 IPM
WIRE SIZE = .045” LINCOLN ULTRACORE 71A85
GAS FLOW = 25-30 CFH C25 GAS
CTWD (STICKOUT) = 3/4”-1 “
FILLER METAL = .045” LINCOLN ULTRACORE 71A85
TIPS: A longer stickout aka contact to work distance CTWD of 3/4” to 1” provides best results Using too short a stickout can result in worm tracks
Did you know?..
