DUAL SHIELD CARBON STEEL 3/8" PLATE 3G PLATE TEST FILL PASSES
Root pass 3g settings were the same watch quick video here
3g dual shield Cover pass video here
METAL TYPE = CARBON STEEL
THICKNESS = 3/8”
WELD TYPE = groove weld FILL PASSES
JOINT TYPE = butt JOINT 22.5 BEVELS, 1/4” GAP, 1/4” BACKING BAR
POSITION = 3G vertical uphill
VOLTS = 24 volts
WIRE SPEED = 330 IPM
WIRE SIZE = .045” LINCOLN 71M
GAS FLOW = 25-30 CFH C25 GAS
CTWD (STICKOUT) = 3/4”-1 “
FILLER METAL = LINCOLN 71M OUTERSHIELD .045"
TIPS:
The first pass shown is a weave over the root. If you are permitted a slight weave, this can be a good option over the root. Some test administrators and procedures strictly limit bead width so be prepare to run stringers beads all the way but stack them carefully so that you have room to penetrate.
A longer stickout aka contact to work distance CTWD of 3/4” to 1” provides best results Using too short a stickout can result in worm tracks
Did you know?..
