DUAL SHIELD FLUX CORE CARBON STEEL 3/8" THICK 3F TEE
scroll down for details and exact settings
WELD PROCESS = DUAL SHIELD FLUX CORE, FCAW-G ( GAS SHIELDED), OUTERSHIELD
METAL TYPE = CARBON STEEL
THICKNESS = 3/8”
WELD TYPE = FILLET
JOINT TYPE = TEE
POSITION = 3F VERTICAL UP
VOLTS = 24 volts
WIRE SPEED = 333 IPM
WIRE SIZE = .045” LINCOLN 71M
GAS FLOW = 25-35 CFH C25 GAS
CTWD (STICKOUT) = 3/4”-1 “
FILLER METAL = LINCOLN 71M OUTERSHIELD .045"
TIPS: VERY LITTLE MANIPULATION NEEDED.
CTWD (CONTACT TO WORK DISTANCE) SHOULD BE 3/4”-1”
A longer stickout aka contact to work distance CTWD of 3/4” to 1” provides best results Using too short a stickout can result in worm tracks
Did you know?..
