DUAL SHIELD FLUX CORE 1/4" THICK 3F FILLET .035" 71M
scroll down for settings
WELD PROCESS = DUAL SHIELD FLUX CORE
VOLTAGE= 23.5
WIRE FEED 370 IPM
METAL TYPE = CARBON STEEL
THICKNESS = 3/16"
WELD TYPE = Fillet weld
JOINT TYPE = tee
POSITION = 3f vertical
FILLER WIRE = .035" lincoln 71M
GAS FLOW = 35 CFH 75/25 (c25)
VOLTAGE AND WIRE SPEED WILL VARY SLIGHTLY FROM MACHINE TO MACHINE AND WITH DIFFERENT BRAND WIRES BUT 23.5 VOLTAGE AND 370 IPM WILL GET YOU IN THE BALL BARK FOR .035" DIAMETER DUAL SHIELD WIRE
