If you are curious about DC vs AC TIG welding, this page should help.
This first video explains why we tig weld aluminum on AC and most other metals like carbon steel, stainless steels, nickel alloys, and titanium on DC.
Not that long ago, there was a pretty big difference in the cost between an AC/DC tig welder and a DC only TIG welder.
There is still a small difference in cost but it is minimal so unless you are doing something very specific like sanitary stainless tubing where a small DC only welder works fine, The best value is an AC/DC tig welder.
I like the digital readout feature on the primeweld tig 325x. It makes setting pulse rates easier.
DC only inverter TIG welders are extremely small and portable.
Some of them weigh less than 20 lbs and are as small as a lunch box.
They do have there place because they are so portable.
With a DC only tig welder, you can weld carbon steel, chromoly, stainless, titanium, inconel, and a bunch of other metals but you cant weld aluminum or magnesium. ( at least not in a practical way).
That is why an AC DC tig welder is usually the best choice for a shop.
With an AC/DC tig welder, there are not limitations as to what metal you can weld.
Whether you are a student working on passing a welding test, hobbyist, or a working welder who wants to sharpen up, I want to encourage you to take the free 7 day test drive and get access to all the courses and over 700 videos.
