What does CTWD mean in Welding?
Did you know?..
CTWD stands for Contact Tip to Work Distance.
Another term thrown around is "stickout."
Both terms refer to GMAW as well as FCAW welding processes.
GMAW is more commonly known as MIG and FCAW is commonly called Flux Core.
no matter the process, CTWD its the distance between the contact tip and the base metal.
Electrical stickout is slightly different because it refers to distance between contact tip and arc.
On certain weld types CTWD and Stick Out can be nearly the same.
Contact tip flush with nozzle...works well for short circuit mig to keep a short stickout CTWD
Contact tip is recessed making it difficult to maintain a short stickout ...but works ok for spray and flux cure
Contact tip protruding slightly...works well for short circuit mig tight fillet welds
Lincoln Electric has some really good information on recommended CTWD for practically every wire and process in their book Procedure Handbook of Arc Welding.
You can find it at JFLF.org which is the James F Lincoln Foundation...a non profit arm of Lincoln electric.
Recommended CTWD ( stickout) can vary quite a bit depending on the process.
For example  while the recommended CTWD for Short circuit mig using .035" er70s6 might be around 1/2" or less...
CTWD for Dual Shield Flux Core using .045" might be 3/4"
Some self shielded flux core wires recommend CTWD of over 1 inch.
Spray transfer MIG also uses longer stickout CTWD than short circuit mig welding.
CTWD matters more than you might think but its worth getting right because once you find the Sweet Spot, it can make a ton of difference in the arc.
If you use too long a CTWD on short circuit mig, you risk lack of fusion.
If you dont use long enough CTWD on dual shield flux core, you might get worm tracks.
Too short a CTWD on spray transfer and its difficult to maintain that smooth spatter free arc.
Like most anything, Excellence is found in the Details.
Paying close attention to details is what will separate you from the pack.
I would like to invite you to go deeper into welding.
I have a new welding video learning platform called welderskills.com and you can take a no risk free trial to see whats behind the curtain.
I think you will be glad you did.
Here is a sample video on TIG welding Aluminum.
Take your free trial today at welderskills.com and learn to weld better quicker.
