confermation of skills
by david allen alders
(portland oregon)
i would like to obtain a copy of my awsd1.1 certification my name is david allen alders i used to work at west coast wire and steel
if you tested at an AWS accredited test facility, and were listed on the national welders data base, then the AWS should be able to provide you with a copy.
But, if you were tested to AWS D1.1 standards by the company you worked for, you will probably need to contact that company and they may or may not comply with your request.
good luck,
