A ck 20 tig torch is one of the most popular water cooled torches ...and for good reason.
If you landed here after searching for a ck 20 tig torch, we have them available at our store along with several other ck tig torches
A CK 20 tig torch is rated at 250 amps and the torch body is just about as small as a #9 air cooled torch.
Available in rigid head or flex head...
pictured below is the flex head ck 20 tig torch.
Why a CK 20 tig torch is a good choice:
  • Super flex cables ( you can opt for standard cables but why?)
  • advanced cooling design keeps the torch head cool
  • excellent and friendly customer support...meaning that if there is a problem, someone on the weldmonger store  team will get on the phone with CK and get it resolved
I use both water cooled and air cooled tig torches.
When I am welding with a 200 amp tig welder like the ck mt200 , I mostly use an air cooled 17 and sometimes a 200 amp trimline 26 style air cooled torch.
But... when I need to weld some thick aluminum or even short production runs of parts, I use a water cooled tig torch like a ck20 because it stays cool in my hand.
I like how simple an air cooled tig torch setup is and I almost always opt for Super flex cables on my air cooled torches.
My mt200 tig welder is a fan on demand machine so its quiet while I am not welding.
Even the best tig coolers make some noise, so with an air cooled tig torch you dont have that going on as background shop noise.
These days, when I use a water cooled tig torch and tig cooler, I just put in some ear plugs.
