Can a Mahe beta 190 hf do stick (rod) welding?
Hi all, I am a retired engineer who is used to mig,gas, and arc (stick) welding. I have recently swapped my Fermi h.f stick welder for a Mahe Beta 190 HF, tig welder that came without the torch. I had it because I want to learn tig welding for ali', but not having a manual for it I do not know how to operate it, or what the symbols on the front panel mean other than gas and flow latency. ANY help would be much appreciated. Many thanks, Bob.
most every tig welder will also stick weld.
you may need to manually swap the leads to get dcep
