TIG SETTINGS FOR BOX CUTTER BLADES
METAL TYPE = CARBON STEEL RAZOR BOX CUTTER BLADE
THICKNESS = .023”
WELD TYPE = GROOVE WELD
JOINT TYPE = BUTT
POSITION = 1G FLAT
AMPERAGE = MACHINE SET TO 25 AMPS WITH FOOT PEDAL
TUNGSTEN = 2% LANTHANATED, 3/32" SHARP LIKE NEEDLE
FILLER WIRE = .030" ER308L
POLARITY =DCEN
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = .2 SEC
POST FLOW = 11 SEC TIPS:
KEEP A TIGHT ARC AND DONT MOVE AHEAD FAR WITHOUT DABBING FILLER ROD
Aim for an arc length that is equal or less than the diameter of your tungsten electrode. Torch angle can be forgiving provided your arc length is tight.
Did you know?...
***Its Easy to sign up
No Ads, No BS style
