best voltage amperage wirefeed settings 3/4" mild steel
by garett
(richmond va USA)
I am mig welding with a miller big blue 400 and suitcase extreme 12 wire feeder . On a t weld of 3/4" mild steel vertical piece is beveld to nearly a quarter plate thickness. 75/25 gas mix.
cannot get the settings right to make a proper weld. What should i set the wire feed speed voltage amperage to for my first and second passes.
I am thinking about 20 volts and close to 300 ipm of wire speed with .035" er70s wire will be close.
its a good starting point anyway. adjust wire speed to sound smooth with no popping and no stubbing and very little weld spatter
Comments for best voltage amperage wirefeed settings 3/4" mild steel
Jul 18, 2011
mild steel yield strength
by: rajyenranjan
At Metal Supplies all of our Mild Steel including our vast Box Section, Tube, Sheet and Angle range is available X-stock for immediate dispatch. We also offer our quick turnaround cutting service to both our commercial and domestic customers. So please take the time to use the drop down menu on the left to view our standard Mild Steel product range; However many Specialist Products, Complementary Services and Non-Standard sizes are also available.
As an incite into the wide ranging possibilities of Mild Steel, we have compiled some basic information on a selection of our most popular grades and complementary services, which are available in various forms such as:
Rounds | Squares
