The Best TIG Welding Videos
Scroll Down to Watch the Best TIG welding Videos
STAINLESS-ROOT-THUMB-FILLET-TIGFINGER
The videos above are 2 of the Best TIG welding videos I have made
stainless-root-thumb
If you are still using the standard cups and hardware that came with your torch, you are probably not getting the best results possible.
A lot of times, the right TIG cup can make all the difference.
It does not matter how good your tig welding machine is if you are using sub standard TIG cups.
What makes for the best TIG welding videos?
Is it loud music on the intro?
fancy transitions or jump cuts?
None of that stuff helps people.
How about clear crisp arc shots and plain explanations along with detailed settings used to get the very best results?
To me, that is what makes for the best tig welding videos.
There are hundreds of free videos on weldingtipsandtricks.com on TIG, MIG, Stick, and Flux core welding but if you learn better with a dedicated course that is organized into an ABC...123 type learning system, then I invite you to take our Free 7 day Test drive at welderskills.com and take advantage of our TIG course for beginners.
