base chart on voltage,wire speed, metal thickness
by j.c.
(tampa,fl)
am looking for a reference chart for welding steel. ie: voltage,wire speed, & thickness of material. knowing that all machines, act different, just because what the dial says is not likely what your going to get. but a small reference chart would help to start. then a little trial and error to find the right combination...
I use this one a lot...
http://www.millerwelds.com/resources/improving-your-skills/mig/
click on the weld calculator icon in the upper right corner. select solid wire or flux core.
