by John
(GUILDFORD,NSW,AUSTRALIA)
Tip Top site
I Bought a TIG P AC/DC 200 Machine 240volts. www.unimig.com.au I sort of worked out your settings.Can you explain your knob settings to my settings for thin alum inum. I use 4043 rods 1.6 2.4 mm with 1.6mm Zirconiated electrodes argon gas. Foot control On 1.6mm checker plate I have trouble starting and burning off the end plate THANKS JOHN
John,
Zirconiated balls up and is hard to use on ends.
I would get some lanth either 1.5 or 2% and taper it a little blunter than for steel.
set the AC balance to where you have about 65% dcen (your manual should tell you where on your ac balance knob does this.)
frequency anywhere from 90-130 should work fine.
i would not worry about pulse if your machine has it.
I think ditching the zirc electrodes and using a taper will help the most.
